Qontrol
Qontrol::Task::GenericTask Member List
This is the complete list of members for Qontrol::Task::GenericTask, including all inherited members.
controled_frame_name_ (defined in Qontrol::Task::GenericTask)Qontrol::Task::GenericTaskprotected
E_ (defined in Qontrol::Task::GenericTask)Qontrol::Task::GenericTaskprotected
f_ (defined in Qontrol::Task::GenericTask)Qontrol::Task::GenericTaskprotected
GenericTask(std::string name, int task_dimension, int optim_vector_dimension)Qontrol::Task::GenericTaskinline
GenericTask(std::string name, int task_dimension, std::shared_ptr< Model::GenericModel > model_ptr)Qontrol::Task::GenericTaskinline
getGradient()Qontrol::Task::GenericTask
getHessian()Qontrol::Task::GenericTask
getJacobianGHC() (defined in Qontrol::Task::GenericTask)Qontrol::Task::GenericTask
getName()Qontrol::Task::GenericTask
getSelectionMatrix()Qontrol::Task::GenericTask
getTaskDimension() (defined in Qontrol::Task::GenericTask)Qontrol::Task::GenericTask
getWeightingMatrix()Qontrol::Task::GenericTask
model_ptr_ (defined in Qontrol::Task::GenericTask)Qontrol::Task::GenericTaskprotected
optim_vector_dimension_ (defined in Qontrol::Task::GenericTask)Qontrol::Task::GenericTaskprotected
reference_frame_ (defined in Qontrol::Task::GenericTask)Qontrol::Task::GenericTaskprotected
resize(int input_size, int output_size)Qontrol::Task::GenericTask
resolution_strategy_ (defined in Qontrol::Task::GenericTask)Qontrol::Task::GenericTaskprotected
selection_matrix_ (defined in Qontrol::Task::GenericTask)Qontrol::Task::GenericTaskprotected
setControledFrameName(std::string frame_name) (defined in Qontrol::Task::GenericTask)Qontrol::Task::GenericTask
setE(Eigen::MatrixXd E)Qontrol::Task::GenericTask
setf(Eigen::VectorXd f)Qontrol::Task::GenericTask
setReferenceFrame(ReferenceFrame reference_frame) (defined in Qontrol::Task::GenericTask)Qontrol::Task::GenericTask
setResolutionStrategy(ResolutionStrategy resolution_strategy) (defined in Qontrol::Task::GenericTask)Qontrol::Task::GenericTask
setSelectionMatrix(Eigen::MatrixXd selection_matrix)Qontrol::Task::GenericTask
setSubStateMatrix(Eigen::MatrixXd &subStateMatrix) (defined in Qontrol::Task::GenericTask)Qontrol::Task::GenericTask
setWeightingMatrix(Eigen::MatrixXd weighting_matrix)Qontrol::Task::GenericTask
subStateMatrix_ (defined in Qontrol::Task::GenericTask)Qontrol::Task::GenericTaskprotected
task_dimension_ (defined in Qontrol::Task::GenericTask)Qontrol::Task::GenericTaskprotected
update(double dt)Qontrol::Task::GenericTaskinlinevirtual
weighting_matrix_ (defined in Qontrol::Task::GenericTask)Qontrol::Task::GenericTaskprotected
