Qontrol
Qontrol::Task::GenericTask Class Reference
Represents a generic task. More...
#include <GenericTask.hpp>
Inheritance diagram for Qontrol::Task::GenericTask:
Public Member Functions
 GenericTask (std::string name, int task_dimension, int optim_vector_dimension)
 Construct a new GenericTask object. More...
 GenericTask (std::string name, int task_dimension, std::shared_ptr< Model::GenericModel > model_ptr)
 Construct a new Base Task object. More...
std::string getName ()
 Get the task name. More...
void resize (int input_size, int output_size)
 Resize the \(E\) matrix and \(\boldsymbol{f}\) vector according to the task. More...
void setE (Eigen::MatrixXd E)
 Set the \(E\) matrix in \( ||E\boldsymbol{x} - \boldsymbol{f}||^2_{SW}\). More...
void setf (Eigen::VectorXd f)
 Set the \(f\) vector in \( ||E\boldsymbol{x} - \boldsymbol{f}||^2_{SW}\). More...
virtual void update (double dt)
 Update \(E\) and \(\boldsymbol{f}\). overrided by the considered implementation of the task. More...
Eigen::MatrixXd getHessian ()
 Get the hessian matrix related to the task. More...
Eigen::VectorXd getGradient ()
 Get the gradient vector. More...
void setSelectionMatrix (Eigen::MatrixXd selection_matrix)
 Set the task selection matrix. More...
void setWeightingMatrix (Eigen::MatrixXd weighting_matrix)
 Set the task weighting matrix. More...
Eigen::MatrixXd getSelectionMatrix ()
 Get the selection matrix. More...
Eigen::MatrixXd getWeightingMatrix ()
 Get the weighting matrix. More...
Eigen::MatrixXd getJacobianGHC ()
int getTaskDimension ()
void setResolutionStrategy (ResolutionStrategy resolution_strategy)
void setControledFrameName (std::string frame_name)
void setReferenceFrame (ReferenceFrame reference_frame)
void setSubStateMatrix (Eigen::MatrixXd &subStateMatrix)
Protected Attributes
std::shared_ptr< Model::GenericModel > model_ptr_
std::string name_
Eigen::MatrixXd E_
Eigen::VectorXd f_
Eigen::MatrixXd selection_matrix_
Eigen::MatrixXd weighting_matrix_
int task_dimension_
int optim_vector_dimension_
ResolutionStrategy resolution_strategy_
Eigen::MatrixXd subStateMatrix_
std::string controled_frame_name_
ReferenceFrame reference_frame_
Detailed Description
Let's consider a task using \(m\) degrees of freedom of a robot with \(n\) degrees of freedom. The optimization variable will be called \( \boldsymbol{x} \in \mathbb{R}^n \)
This task is expressed as \( ||E\boldsymbol{x} - \boldsymbol{f}||^2_{SW}\). where \(E \in \mathbb{R}^{m \times n}\) and \(\boldsymbol{f} \in \mathbb{R}^{m}\), \(S \in \mathbb{R}^{m \times m}\) is a selection matrix and \(W \in \mathbb{R}^{m \times m}\) is weighting matrix.
Constructor & Destructor Documentation
◆ GenericTask() [1/2]
Qontrol::Task::GenericTask::GenericTask ( std::string  name,
int  task_dimension,
inline
This constructor is used when creating a custom task The constructor resizes the problem and sets the selection and weighting matrices to the identity.
Parameters
nameThe name of the task
task_dimensionThe dimension of the task, \(m\)
optim_vector_dimensionThe dimension of the optimization vector, \(n\)
◆ GenericTask() [2/2]
int  task_dimension,
inline
This constructor is used when creating an implemented task. It uses the model_ptr to automatically update the task. The constructor resizes the problem and set the selection and weighting matrices to the identity.
Parameters
model_ptra pointer toward the robot model
Member Function Documentation
◆ getGradient()
auto Qontrol::Task::GenericTask::getGradient ( )
The gradient is computed as \( -2.0 E^T S W f \)
Warning
Strictly speaking the weighting matrix \(W\) used is the square root of the one given in setWeightingMatrix()
Returns
Eigen::VectorXd \(\in \mathbb{R}^{m} \)
◆ getHessian()
auto Qontrol::Task::GenericTask::getHessian ( )
The hessian is computed as \( 2.0 E^T S W E^t \)
Warning
Returns
Eigen::MatrixXd \(\in \mathbb{R}^{n \times n} \)
◆ getName()
auto Qontrol::Task::GenericTask::getName ( )
Get the task name.
Returns
std::string
◆ getSelectionMatrix()
auto Qontrol::Task::GenericTask::getSelectionMatrix ( )
Returns
Eigen::MatrixXd \(\in \mathbb{R}^{m \times m} \)
◆ getWeightingMatrix()
auto Qontrol::Task::GenericTask::getWeightingMatrix ( )
Returns
◆ resize()
void Qontrol::Task::GenericTask::resize ( int  input_size,
int  output_size
Parameters
input_sizeThe task size, \(m\)
output_sizeThe optimization vector size, \(n\)
◆ setE()
void Qontrol::Task::GenericTask::setE ( Eigen::MatrixXd  E)
Parameters
E\(\in \mathbb{R}^{m \times n} \)
◆ setf()
void Qontrol::Task::GenericTask::setf ( Eigen::VectorXd  f)
Parameters
f\(\in \mathbb{R}^{m} \)
◆ setSelectionMatrix()
void Qontrol::Task::GenericTask::setSelectionMatrix ( Eigen::MatrixXd  selection_matrix)
Parameters
selection_matrix\(\in \mathbb{R}^{m \times m} \)
◆ setWeightingMatrix()
void Qontrol::Task::GenericTask::setWeightingMatrix ( Eigen::MatrixXd  weighting_matrix)
Parameters
weighting_matrix\(\in \mathbb{R}^{m \times m} \)
◆ update()
The documentation for this class was generated from the following files:
