The following example solves a qp problem expressed at the joint velocity level such that:
\begin{equation}\begin{array}{ccc}\boldsymbol{\dot{q}}^{opt} = & \underset{\boldsymbol{\dot{q}}}{\mathrm{argmin}} & ||J(\boldsymbol{q})\boldsymbol{\dot{q}} - \boldsymbol{v}^{target} || + \omega || \boldsymbol{\dot{q}} ||^2\\& \textrm{s.t.} & \boldsymbol{\dot{q}^{min}} \leq \boldsymbol{\dot{q}} \leq \boldsymbol{\dot{q}^{max}}. \\ & & \boldsymbol{q}^{min} \leq \boldsymbol{q}(\boldsymbol{\dot{q}}) \leq \boldsymbol{q}^{max} \end{array} \end{equation}
The robot main tasks consists in following a simple trajectory defined in Cartesian space. The mujoco library is used to simulate the robot behaviour. In this example the joint velocity constraint is defined as a custom constraint, meaning that the user as to update the constraint manually.
Simulation
To run this example run the following command from the build/examples directory:
./QontrolCustomConstraint robot_name
where robot_name can be either panda or ur5
Full code
15 #include "mujoco/mujoco_sim.h"
16 #include "Qontrol/Qontrol.hpp"
17 #include "trajectory_generation/trajectory_generation.h"
19 #define MUJOCO_PLUGIN_DIR "mujoco_plugin"
22 using namespace Qontrol;
24 class MujocoQontrol :
public MujocoSim
28 std::shared_ptr<Qontrol::Model::RobotModel<Qontrol::ModelImpl::PINOCCHIO>> model;
29 std::shared_ptr<Qontrol::JointVelocityProblem> velocity_problem;
30 std::shared_ptr<Qontrol::Task::CartesianVelocity<Qontrol::ControlOutput::JointVelocity>> main_task;
31 std::shared_ptr<Qontrol::Constraint::GenericConstraint> custom_constraint;
32 pinocchio::SE3 init_pose;
36 TrajectoryGeneration* traj;
37 std::string resource_path;
38 void initController()
override
43 velocity_problem = std::make_shared<Qontrol::JointVelocityProblem>(model);
45 auto regularisation_task = velocity_problem->task_set->add<
Task::JointVelocity>(
"RegularisationTask",1e-5);
49 velocity_problem->constraint_set->add(
"CustomConstraint",model->getNrOfDegreesOfFreedom());
51 mju_copy(d->qpos, m->key_qpos, m->nu);
52 robot_state.joint_position.resize(model->getNrOfDegreesOfFreedom());
53 robot_state.joint_velocity.resize(model->getNrOfDegreesOfFreedom());
54 for (
int i=0; i<model->getNrOfDegreesOfFreedom() ; ++i)
56 robot_state.joint_position[i] = d->qpos[i];
57 robot_state.joint_velocity[i] = d->qvel[i];
59 model->setRobotState(robot_state);
61 traj =
new TrajectoryGeneration(resource_path+
"trajectory.csv", m->opt.timestep);
64 void updateController()
override
67 for (
69 robot_state.joint_position[i] = d->qpos[i];
70 robot_state.joint_velocity[i] = d->qvel[i];
72 model->setRobotState(robot_state);
74 pinocchio::SE3 current_pose(model->getFramePose(model->getTipFrameName()).matrix());
76 pinocchio::SE3 traj_pose(traj->pose.matrix());
77 const pinocchio::SE3 tipMdes = current_pose.actInv(traj_pose);
78 auto err = pinocchio::log6(tipMdes).toVector();
79 Eigen::Matrix<double,6,1> p_gains;
80 p_gains << 10,10,10,10,10,10;
81 Eigen::Matrix<double,6,1> xd_star = p_gains.cwiseProduct(err);
82 main_task->setTargetVelocity(xd_star);
83 custom_constraint->setConstraintMatrix(Eigen::MatrixXd::Identity(
84 model->getNrOfDegreesOfFreedom(), model->getNrOfDegreesOfFreedom()));
85 custom_constraint->setUpperBounds(model->getJointVelocityLimits());
86 custom_constraint->setLowerBounds(-model->getJointVelocityLimits());
87 velocity_problem->update(m->opt.timestep);
89 if (velocity_problem->solutionFound())
91 sendJointVelocity(velocity_problem->getJointVelocityCommand());
97 int main(
int argc,
const char** argv) {
98 MujocoQontrol mujoco_qontrol;
99 Qontrol::Log::Logger::parseArgv(argc, argv);
102 mjv_defaultScene(&scn);
105 mjv_defaultCamera(&cam);
108 mjv_defaultOption(&opt);
111 mjv_defaultPerturb(&pert);
114 auto sim = std::make_unique<mj::Simulate>(
115 std::make_unique<mj::GlfwAdapter>(), &cam, &opt, &pert,
true
119 std::string robot = argv[1];
120 const char* mujoco_model =
"./resources/"+robot+
"/scene.xml";
121 mujoco_qontrol.resource_path =
124 std::thread physicsthreadhandle( &MujocoQontrol::PhysicsThread, mujoco_qontrol, sim.get(), mujoco_model);
128 physicsthreadhandle.join();
Explanation of the code
Declaration
First we declare all the objects that will be used to define our problem.
0 std::shared_ptr<Qontrol::Model::RobotModel<Qontrol::ModelImpl::PINOCCHIO>> model;
We use pinocchio for our model library.
28 std::shared_ptr<Qontrol::JointVelocityProblem> velocity_problem;
The output of our qp controller is at the velocity level.
29 std::shared_ptr<Qontrol::Task::CartesianVelocity<Qontrol::ControlOutput::JointVelocity>> main_task;
The main task is expressed as a Cartesian velocity task.
30 std::shared_ptr<Qontrol::Constraint::GenericConstraint> custom_constraint;
Here we declare the custom constraint as a GenericConstraint.
Initialization
override
41 Model::RobotModel<ModelImpl::PINOCCHIO>::loadModelFromFile(resource_path+
"robot.urdf");
During initialization we instantiate the model with the robot urdf.
42 velocity_problem = std::make_shared<Qontrol::JointVelocityProblem>(model);
We initialize the problem by giving it the model. By default, the qpmad library is used.
44 main_task = velocity_problem->task_set->add<Task::CartesianVelocity>(
"MainTask");
45 auto regularisation_task = velocity_problem->task_set->add<Task::JointVelocity>(
We then fill the task set of velocity_problem with the main task and the regularisation task. Each tasks is given a name and a relative weight \( \omega \). This weight can be modified at any time. In this example, the regularisation tasks is defined as a joint veloicty task. Its means that this task will minimize the overall robot joint veloicty.
46 auto joint_configuration_constraint = velocity_problem->constraint_set->add<Constraint::JointConfiguration>(
"JointConfigurationConstraint");
We then fill the constraint set of velocity_problem with the pre-implemented joint configuration constraint. Each constraint is given a name. This constraint will automatically be updated during the update of Qontrol.
Then we add our custom constraint. We give it a name to identify it and also the size of the constraint. This size will be used by Qontrol to resize the constraint set.
54 for (
We create the robot state and fill it with the simulated robot current state.
61 traj =
We create a simple trajectory that has been precalculated and store in a csv file. This trajectory start at the robot current Cartesian pose and does a translation of (-0.1, -0,1, -0.1) m.
Update
65 void updateController()
override
68 for (
70 robot_state.joint_position[i] = d->qpos[i];
71 robot_state.joint_velocity[i] = d->qvel[i];
73 model->setRobotState(robot_state);
75 pinocchio::SE3 current_pose(model->getFramePose(model->getTipFrameName()).matrix());
The update function is called every milliseconds. At the beginning of each update we fill the new robot state according to the simulated robot.
We also update the trajectory so that it gives the next Cartesian pose to reach in 1 ms.
77 pinocchio::SE3 traj_pose(traj->pose.matrix());
78 const pinocchio::SE3 tipMdes = current_pose.actInv(traj_pose);
79 auto err = pinocchio::log6(tipMdes).toVector();
80 Eigen::Matrix<double,6,1> p_gains;
81 p_gains << 10,10,10,10,10,10;
82 Eigen::Matrix<double,6,1> xd_star = p_gains.cwiseProduct(err);
We then compute the desired Cartesian velocity using a simple proportionnal controller. Pinocchio is used to compute the error between the desired Cartesian pose and the current Cartesian pose. This is done by the log6 function. The p_gains are the proportionnal gains of the controller.
83 main_task->setTargetVelocity(xd_star);
The desired Cartesian velocity is then fed to the main task.
84 custom_constraint->setConstraintMatrix(Eigen::MatrixXd::Identity(
85 model->getNrOfDegreesOfFreedom(), model->getNrOfDegreesOfFreedom()));
86 custom_constraint->setUpperBounds(model->getJointVelocityLimits());
87 custom_constraint->setLowerBounds(-model->getJointVelocityLimits());
Here we update the custom constraint. We first set the constraint matrix A to the identity matrix. Then we set the lower and upper bounds of the constraint with the robot joint velocity limits.
88 velocity_problem->update(m->opt.timestep);
90 if (velocity_problem->solutionFound())
92 sendJointVelocity(velocity_problem->getJointVelocityCommand());
Once we updated the necassary tasks and constraints we can update the whole problem. If a solution to the problem exist we can then get it and send it to the simulated robot.
Main function
98 int main(
int argc,
99 MujocoQontrol mujoco_qontrol;
100 Qontrol::Log::Logger::parseArgv(argc, argv);
103 mjv_defaultScene(&scn);
106 mjv_defaultCamera(&cam);
109 mjv_defaultOption(&opt);
112 mjv_defaultPerturb(&pert);
115 auto sim = std::make_unique<mj::Simulate>(
116 std::make_unique<mj::GlfwAdapter>(), &cam, &opt, &pert,
true
120 std::string robot = argv[1];
121 const char* mujoco_model =
"/scene.xml";
122 mujoco_qontrol.resource_path =
125 std::thread physicsthreadhandle( &MujocoQontrol::PhysicsThread, mujoco_qontrol, sim.get(), mujoco_model);
129 physicsthreadhandle.join();
The main function function fetches the robot name given in argv and starts the Mujoco simulation.
