Qontrol
Qontrol::Constraint::GenericConstraint Class Reference
Represents a generic constraint. More...
#include <GenericConstraint.hpp>
Inheritance diagram for Qontrol::Constraint::GenericConstraint:
Public Member Functions
 GenericConstraint (std::string name, int constraint_size, int optimization_vector_size)
 Construct a new GenericConstraint object. More...
 GenericConstraint (std::string name, int constraint_size, std::shared_ptr< Model::GenericModel > model_ptr)
 Construct a new Base onstraint object. More...
virtual void update (double dt)
 Update \(A\), \(\boldsymbol{lb}\) and \(\boldsymbol{ub}\) overrided by the considered implementation of the constraint. More...
int getSize ()
 Get the constraint size. More...
std::string getName ()
 Get the constraint name. More...
void setConstraintMatrix (Eigen::MatrixXd constraint_matrix)
 Set the constraint matrix \( A \). More...
void setUpperBounds (Eigen::VectorXd upper_bound)
 Set the constraint upper bounds \( \boldsymbol{ub}\). More...
void setLowerBounds (Eigen::VectorXd lower_bound)
 Set the constraint lower bounds \( \boldsymbol{lb}\). More...
void resize (int task_size, int constraint_size)
 Resize the constraint matrices and vectors according to the task size and new constraint size. More...
Eigen::MatrixXd getConstraintMatrix ()
 Get the constraint matrix \( A \). More...
Eigen::VectorXd getUpperBounds ()
 Get the constraint upper bounds \( \boldsymbol{ub}\). More...
Eigen::VectorXd getLowerBounds ()
 Get the constraint lower bounds \( \boldsymbol{lb}\). More...
Public Attributes
Eigen::VectorXd lower_limit
Eigen::VectorXd upper_limit
Protected Attributes
std::shared_ptr< Model::GenericModelmodel_ptr_
int constraint_size_
int optimization_vector_size_
Detailed Description
In a qp problem a constraint is expressed as an inequality linerarly dependent to the optimization vector. Let's consider a constraint constraining \(m\) degrees of freedom of a robot with \(n\) degrees of freedom. The optimization variable will be called \( \boldsymbol{x} \in \mathbb{R}^n \)
The constraint is expressed as \( \boldsymbol{lb} \leq A \boldsymbol{x} \leq \boldsymbol{ub}\). \( \boldsymbol{lb} \in \mathbb{R}^m \) and \( \boldsymbol{ub} \in \mathbb{R}^m \) are respecitvely the lower bound and the upper bound of the constraint. \( A \in \mathbb{R}^{m\times n} \) is the constraint matrix
Constructor & Destructor Documentation
◆ GenericConstraint() [1/2]
Qontrol::Constraint::GenericConstraint::GenericConstraint ( std::string  name,
inline
This constructor is used when creating a custom constraint The constructor resizes the constraint matrices and vector
Parameters
nameThe constraint name
constraint_sizeThe dimension of the constraint
◆ GenericConstraint() [2/2]
std::shared_ptr< Model::GenericModel model_ptr
inline
This constructor is used when creating an implemented constraint. It uses the model_ptr to automatically update the constraint. The constructor resizes the constraint matrices and vector
Parameters
model_ptrA pointer to the model object
Member Function Documentation
◆ getConstraintMatrix()
auto Qontrol::Constraint::GenericConstraint::getConstraintMatrix ( )
Returns
Eigen::VectorXd \( \in \mathbb{R}^{m \times n} \)
◆ getLowerBounds()
auto Qontrol::Constraint::GenericConstraint::getLowerBounds ( )
Returns
Eigen::VectorXd \( \in \mathbb{R}^m \)
◆ getName()
auto Qontrol::Constraint::GenericConstraint::getName ( )
Returns
std::string
◆ getSize()
auto Qontrol::Constraint::GenericConstraint::getSize ( )
Returns
int
◆ getUpperBounds()
auto Qontrol::Constraint::GenericConstraint::getUpperBounds ( )
Returns
◆ resize()
void Qontrol::Constraint::GenericConstraint::resize ( int  task_size,
int  constraint_size
Parameters
task_size
constraint_size
◆ setConstraintMatrix()
void Qontrol::Constraint::GenericConstraint::setConstraintMatrix ( Eigen::MatrixXd  constraint_matrix)
Parameters
lower_bound\( \in \mathbb{R}^{m \times n} \)
◆ setLowerBounds()
void Qontrol::Constraint::GenericConstraint::setLowerBounds ( Eigen::VectorXd  lower_bound)
Parameters
lower_bound\( \in \mathbb{R}^m \)
◆ setUpperBounds()
void Qontrol::Constraint::GenericConstraint::setUpperBounds ( Eigen::VectorXd  upper_bound)
Parameters
upper_bound\( \in \mathbb{R}^m \)
◆ update()
The documentation for this class was generated from the following files:
