Qontrol
Qontrol::Constraint Namespace Reference
Constraint. More...
Classes
class  ConstraintSet
 Handle all the constraints added to the problem. More...
class  GenericConstraint
 Represents a generic constraint. More...
class  JointConfiguration
 Implemtentation of a joint configuration constraint. More...
class  JointConfiguration< Qontrol::ControlOutput::JointTorque >
 \( \boldsymbol{q}^{min} \leq \boldsymbol{q}(\boldsymbol\tau) \leq \boldsymbol{q}^{max}\) More...
class  JointConfiguration< Qontrol::ControlOutput::JointVelocity >
 \( \boldsymbol{q}^{min} \leq \boldsymbol{q}(\boldsymbol{\dot{q}}) \leq \boldsymbol{q}^{max}\) More...
class  JointTorque
 Implemtentation of a joint torque constraint. More...
class  JointTorque< Qontrol::ControlOutput::JointTorque >
 \( \boldsymbol{\tau}^{min} \leq \boldsymbol{\tau} \leq \boldsymbol{\tau}^{max}\) More...
class  JointVelocity
 Implemtentation of a joint velocity constraint. More...
class  JointVelocity< Qontrol::ControlOutput::JointTorque >
 \( \boldsymbol{\dot{q}}^{min} \leq \boldsymbol{\dot{q}}(\boldsymbol\tau) \leq \boldsymbol{\dot{q}}^{max}\) More...
class  JointVelocity< Qontrol::ControlOutput::JointVelocity >
 \( \boldsymbol{\dot{q}}^{min} \leq \boldsymbol{\dot{q}} \leq \boldsymbol{\dot{q}}^{max}\) More...
Detailed Description
