Qontrol
Classes | |
| class | CartesianAcceleration |
| Implementation of a Cartesian Acceleration task. More... | |
| class | CartesianAcceleration< Qontrol::ControlOutput::JointAcceleration > |
| \( \boldsymbol{\ddot{q}}^{opt} = \underset{\boldsymbol{\ddot{q}}}{\mathrm{argmin}} || \boldsymbol{\dot{v}}(\boldsymbol{\ddot{q}}) - \boldsymbol{\dot{v}}^{target} ||^2_{SW} \) More... | |
| class | CartesianAcceleration< Qontrol::ControlOutput::JointTorque > |
| \( \boldsymbol{\tau}^{opt} = \underset{\boldsymbol{\tau}}{\mathrm{argmin}} || \boldsymbol{\dot{v}}(\boldsymbol{\tau}) - \boldsymbol{\dot{v}}^{target} ||^2_{SW} \) More... | |
| class | CartesianVelocity |
| Implementation of a Cartesian velocity task. More... | |
| class | CartesianVelocity< Qontrol::ControlOutput::JointVelocity > |
| \( \boldsymbol{\dot{q}}^{opt} = \underset{\boldsymbol{\dot{q}}}{\mathrm{argmin}} || \boldsymbol{v}(\boldsymbol{\dot{q}}) - \boldsymbol{v}^{target} ||^2_{SW} \) More... | |
| class | GenericTask |
| Represents a generic task. More... | |
| class | JointAcceleration |
| Implemtentation of a joint acceleration task. More... | |
| class | JointAcceleration< Qontrol::ControlOutput::JointAcceleration > |
| \( \boldsymbol{\ddot{q}}^{opt} = \underset{\boldsymbol{\ddot{q}}}{\mathrm{argmin}} || \boldsymbol{\ddot{q}} - \boldsymbol{\ddot{q}}^{target} ||^2_{SW} \) More... | |
| class | JointTorque |
| Implemtentation of a joint torque task. More... | |
| class | JointTorque< Qontrol::ControlOutput::JointTorque > |
| \( \boldsymbol{\tau}^{opt} = \underset{\boldsymbol{\tau}}{\mathrm{argmin}} || \boldsymbol{\tau} - \boldsymbol{\tau}^{target} ||^2_{SW} \) More... | |
| class | JointVelocity |
| Implemtentation of a joint velocity task. More... | |
| class | JointVelocity< Qontrol::ControlOutput::JointVelocity > |
| \( \boldsymbol{\dot{q}}^{opt} = \underset{\boldsymbol{\dot{q}}}{\mathrm{argmin}} || \boldsymbol{\dot{q}} - \boldsymbol{\dot{q}}^{target} ||^2_{SW} \) More... | |
| class | TaskSet |
| Handle all the tasks added to the problem. More... | |
Task.
