Qontrol
Qontrol::Task::TaskSet< output > Class Template Reference
Handle all the tasks added to the problem. More...
#include <TaskSet.hpp>
Public Member Functions
 TaskSet (std::shared_ptr< Model::GenericModel > model_library)
std::shared_ptr< Task::GenericTask > add (std::string task_name, int task_dimension, double task_weight=1.0)
 Add a custom task to the task set. More...
std::shared_ptr< Task::GenericTask > add (std::string task_name, int task_dimension, int optim_vector_dimension, double task_weight=1.0)
template<template< Qontrol::ControlOutput output2 > class ControlInput>
std::shared_ptr< ControlInput< output > > add (std::string task_name, double task_weight=1.0)
 Add an implemented task in the task set. More...
bool exist (std::string task_name)
 Check if a task exists in the task set. More...
void getNames ()
 Get the names of all the tasks ordered in their declaration order. More...
void update (double dt)
 Call the update function of all the tasks in the task set. More...
std::vector< std::shared_ptr< Task::GenericTask > > getTasks ()
 Get all the tasks. More...
std::vector< double > getTasksWeight ()
 Get the relative weight of all the tasks in the task set ordered in their declaration order. More...
int getTaskIndex (std::string task_name)
 Get the index of a task in the task set. More...
void remove (std::shared_ptr< Task::GenericTask > task_ptr)
 Remove a task from the task set. More...
void remove (std::string task_name)
bool setTaskWeight (std::shared_ptr< Task::GenericTask > task, double task_weight)
 Set a task weight relatively to all the tasks in the task set. More...
bool setTaskWeight (std::string task_name, double task_weight)
Protected Attributes
std::shared_ptr< Model::GenericModel > model_ptr_
std::vector< std::string > tasks_names_
Detailed Description
template<Qontrol::ControlOutput output>
class Qontrol::Task::TaskSet< output >
Template Parameters
outputThe tasks control output
Member Function Documentation
◆ add() [1/2]
std::shared_ptr<ControlInput<output> > Qontrol::Task::TaskSet< output >::add ( std::string  task_name,
double  task_weight = 1.0
inline
Template Parameters
ControlInputThe input type of the task
Parameters
task_nameThe name of the task
task_weightThe relative weight of the task
Returns
std::shared_ptr<ControlInput<output>> The pointer to the task
◆ add() [2/2]
std::shared_ptr<Task::GenericTask> Qontrol::Task::TaskSet< output >::add ( std::string  task_name,
int  task_dimension,
inline
Parameters
task_dimensionThe dimension of the task
Returns
std::shared_ptr<Task::GenericTask> The pointer to the task
◆ exist()
bool Qontrol::Task::TaskSet< output >::exist ( std::string  task_name)
inline
Parameters
task_name
◆ getNames()
void Qontrol::Task::TaskSet< output >::getNames ( )
inline
◆ getTaskIndex()
int Qontrol::Task::TaskSet< output >::getTaskIndex ( std::string  task_name)
inline
Parameters
task_name
Returns
int
◆ getTasks()
std::vector<std::shared_ptr<Task::GenericTask> > Qontrol::Task::TaskSet< output >::getTasks ( )
inline
Get all the tasks.
Returns
std::vector<std::shared_ptr<Task::GenericTask>>
◆ getTasksWeight()
std::vector<double> Qontrol::Task::TaskSet< output >::getTasksWeight ( )
inline
Returns
std::vector<double>
◆ remove() [1/2]
void Qontrol::Task::TaskSet< output >::remove ( std::shared_ptr< Task::GenericTask >  task_ptr)
inline
Parameters
task_ptr
◆ remove() [2/2]
void Qontrol::Task::TaskSet< output >::remove ( std::string  task_name)
inline
Parameters
task_ptr
◆ setTaskWeight() [1/2]
bool Qontrol::Task::TaskSet< output >::setTaskWeight ( std::shared_ptr< Task::GenericTask >  task,
double  task_weight
inline
Parameters
taskthe considered task
task_weightthe weight of the task
◆ setTaskWeight() [2/2]
bool Qontrol::Task::TaskSet< output >::setTaskWeight ( std::string  task_name,
double  task_weight
inline
Parameters
taskthe considered task name
◆ update()
void Qontrol::Task::TaskSet< output >::update ( double  dt)
inline
The documentation for this class was generated from the following file:
